configure lldp ports vendor-specific dcbx
configure lldp ports [all | port_list] [advertise | no-advertise] vendor-specific dcbx {ieee|baseline}
Description
Configures the LLDP port to advertise or not to advertise Data Center Bridging Exchange (DCBX) information to its neighbors.
Syntax Description
all
Specifies all ports on the switch.
port_list
Specifies one or more ports or slots and ports.
advertise
Specifies to send the information to neighbors.
no-advertise
Specifies not to send the information to neighbors.
ieee
Specifies the DCBX protocol defined in IEEE 802.1Qaz.
baseline
Specifies the DCBX protocol known as Baseline Version 1.01, which was defined before IEEE 802.1Qaz.
Default
No advertisement for both DCBX protocols.
Usage Guidelines
If you do not specify a protocol with this command, the advertise option enables advertisement for the IEEE 802.1Qaz protocol, and the no-advertise option disables advertisement for both protocols.
The following command advertises DCBX information according to IEEE 802.1Qaz for port 1:5:
configure lldp ports 1:5 advertise vendor specific dcbx
The following command advertises DCBX information according to Baseline Version 1.01 for port 2:1:
configure lldp ports 2:1 advertise vendor specific dcbx baseline
The following command disables advertisement of DCBX information on all ports:
configure lldp ports all no-advertise vendor specific dcbx
This command was first available in ExtremeXOS 12.6.
Platform Availability
